| CM 871 help please - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM 871 help please (/showthread.php?tid=3919) |
RE: CM 871 help please - Rawze - 12-28-2018 (12-26-2018 )Ryeguy475 Wrote: ... It has a vibration under load that I just cannot seem to solve Is the truck is de-mandated (deleted) ? if so, by who? Bad programming is notorious for making the same kinds of internal engine vibrations, usually roughly in the 1350 - 1500 rpm range too. A slipped injection cam after the inframe can do this too. A lot of things can go wrong with an ISX inframe, and most shops set themselves up for doing the job half-arssed at best. Just read through the Waterloo inframe adventure that I ended up helping him straighten out... What a nightmere that was. It reads like a nightmere novel saga... http://rawze.com/forums/showthread.php?tid=2972&pid=25356#pid25356 RE: CM 871 help please - Mrkentee - 12-28-2018 (12-27-2018 )slowpoke Wrote: just to mention, when mine had an (engine vibration with a slight fuel knock) turned out to be a timing actuator i started by swapping out rear metering actuator with a known good used one i had no change. put that one on front cyl. no change except now i could hear knocking at idle, put original back on still knocking then swapped out front timing actuator, knocking gone almost immediately, engine smoothed right out, pulled right down to 1150 rpm and up to 1800 rpm just to try, still no knock or vibration. but i was lucky enough to have kept two actuators as spares . there not cheap just to try out. Was that knock and vibration constant, or only under a load? RE: CM 871 help please - Ryeguy475 - 12-28-2018 (12-28-2018 )Rawze Wrote:(12-26-2018 )Ryeguy475 Wrote: ... It has a vibration under load that I just cannot seem to solve Hi Rawze, Thanks for your time, yes the truck is deleted, it was done before I bought it. The guy that did it lives near me and he supposedly does good work. I can’t tell who’s “program” he uses. I’m not sure. This has been hell though I can tell you that. I had the inframe done due to a cracked piston, ran it for a year then this vibration under load started. My (ex) mechanic told me it was in my imagination lol. Well I changed the clutch, trans, vibration dampener then the CRANKSHAFT broke. Put crank + bearings etc in got it back, vibration still there. Took ecm out had an updated tune put in, ran great for a few days then vibration came right back. Is 265 psi fuel too low when pulling under 90% load? RE: CM 871 help please - Ryeguy475 - 12-28-2018 Oh btw odometer reads 642k Miles, 26,200 engine hours. They did rush the inframe job, it was done in 2 days. Cummins parts w reman head. RE: CM 871 help please - Rawze - 12-28-2018 (12-28-2018 )Ryeguy475 Wrote: Hi Rawze, I would have the program double checked to ensure it is safe, even if you don't suspect it as being a cause if you care about your engine and its longevity at all. Your welcome to e-mail me the program out of it and I will look it over with an objective opinion if you like. I PM'd you my number. RE: CM 871 help please - Ryeguy475 - 01-01-2019 (01-01-2019 )LRT1549 Wrote: Pay attention to when you have the vibration. See if it's vibrating while in a pull where you are at 100% throttle. Then when it's vibrating look at you boost pressure. It doesn’t make any difference what the boost is, as soon as it gets to where it’s working it vibrates. I’ve seen where many ppl complained about this type of vibration on these. Must be a common thing, I’m just worried the engine will come apart again! RE: CM 871 help please - shoe128 - 01-01-2019 (12-27-2018 )Roysbigtoys Wrote:(12-26-2018 )Ryeguy475 Wrote: Hello, not sure if you had and looking to replace or don't have and lookingto install but maybe check this guys mine was 647.00 GENERAL RADIATOR.COM id call |
