ISX CM2350 Oil Usage and Fuel Economy - Suggestions? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: ISX CM2350 Oil Usage and Fuel Economy - Suggestions? (/showthread.php?tid=4096) Pages: 1 2 |
RE: ISX CM2350 Oil Usage and Fuel Economy - Suggestions? - imalumberjack - 02-04-2019 (02-04-2019 )Waterloo Wrote:871 and cm2350 are different. I used bore scopes and mirrors and every other thing I could think of .... I can see where its at :-) but only little glimpse's of actual cam lobes.(02-04-2019 )imalumberjack Wrote: On the 2250 you cant see the cam and I think 2350 is the same. RE: ISX CM2350 Oil Usage and Fuel Economy - Suggestions? - smorgan87 - 02-05-2019 If its the same model as mine cummins had a recall for bad rings, carbon packing and polishing liners. Mine was partially inframed at about 370k. May be worth a call to the dealer. RE: ISX CM2350 Oil Usage and Fuel Economy - Suggestions? - Rawze - 02-05-2019 (02-04-2019 )imalumberjack Wrote: On the 2250 you cant see the cam and I think 2350 is the same. eehh??? -- That is an incoreect statement completely. Open the engine valve cover and take a look. RE: ISX CM2350 Oil Usage and Fuel Economy - Suggestions? - imalumberjack - 02-05-2019 (02-05-2019 )Rawze Wrote:On mine you cannot (isx 12) I thought the 15 would be the same? ......maybe that's what I get for ...thinking ... :-)(02-04-2019 )imalumberjack Wrote: On the 2250 you cant see the cam and I think 2350 is the same. RE: ISX CM2350 Oil Usage and Fuel Economy - Suggestions? - Unilevers - 02-05-2019 a 12 is different than a 15. RE: ISX CM2350 Oil Usage and Fuel Economy - Suggestions? - imalumberjack - 02-05-2019 (02-05-2019 )Unilevers Wrote: a 12 is different than a 15.Yes, but along the way I have found a lot of the parts are the same as 15 .... just located differently ..... that being said I did not know the cam was "that" differently located or I would not have spoke ......my bad. RE: ISX CM2350 Oil Usage and Fuel Economy - Suggestions? - Volvo8873 - 02-05-2019 For the OP I would think you have some MAJOR issue if your truck is guzzling that much oil!?! RE: ISX CM2350 Oil Usage and Fuel Economy - Suggestions? - Rawze - 02-05-2019 (02-04-2019 )Smooth Wrote: .. Soemthing is very wrong there. Like others have just mentioned, even on a fresh inframe it should not be nearly that much. I think the first 8,000 miles on my own inframe, I used about 2/3 gallon. - After that, it settled and has the typical ~1 gallon in 20k miles+. Mine did however drop 0.7 mpg for the first ~80,000 miles until everything loosened up again, then came back to normal ... just thought I would mention that if others are curious. |
