Dash DPF gauge - Printable Version
+--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70)
+--- Thread: Dash DPF gauge (/showthread.php?tid=4928)
Pages: 1 2
RE: Dash DPF gauge - Mattman - 10-19-2019
That's what I was figuring that the differnital pressure sensor was telling the ECM and the ECM would say what to display.
I thought if it was a more accurate reading it would be a nice feature. Not necessarily needed just another gauge to display how things were doing.
RE: Dash DPF gauge - Moose - 10-19-2019
The digital gauge in the Paccar Smartnav just mirrors the “soot load” parameter broadcast. You can find the same in Insite.
RE: Dash DPF gauge - uncleal13 - 10-19-2019
I have a Scangauge D, programmed the X-Gauges to read off the Detroit One-Box.
I can read DPF in/out/differential pressures. Inlet and outlet NOx sensor readings, DOC in and out temperatures, DPF out temperature, SCR temperatures. Low and high pressure fuel lines.
