| rough idle bad milage weak jakes - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: rough idle bad milage weak jakes (/showthread.php?tid=5023) Pages: 1 2 |
RE: rough idle bad milage weak jakes - shawnkw - 09-01-2019 (09-01-2019 )Rawze Wrote:(09-01-2019 )shawnkw Wrote: 2011 cm2250 isx15 symptoms are a really rough idle, bad mileage down to 5.5 from 6.7, and the jakes aren't as strong as they used to be. truck is a day cab local fuel hauler. I idle a lot pumping off but I pump at 900rpm. I got a malfunction indicator lamp that came on about 150 miles ago. I made it back to the yard without any issues. Im going to clean all the sensors tomorrow. Rail leak and injector cut out test I have not done. I will have to buy the software and I am trying to learn as much as I can to fix things myself. thankyou |
