| Cm871 new oil pump pressure - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm871 new oil pump pressure (/showthread.php?tid=5146) Pages: 1 2 |
RE: Cm871 new oil pump pressure - Lonestar10 - 10-05-2019 New old stock. so still new never used but is older. term NOS is used alot in classics new parts that were never used but are older. RE: Cm871 new oil pump pressure - Bigstank - 10-05-2019 (10-05-2019 )Lonestar10 Wrote: New old stock. so still new never used but is older. term NOS is used alot in classics new parts that were never used but are older.Ok gotcha. This pump is the new one that cant be shimmed with dimes for more psi RE: Cm871 new oil pump pressure - Waterloo - 10-06-2019 Have you changed out the oil pressure sending unit? It is located driver side of block, behind the fuel filter. Just a thought, and an inexpensive part to replace. |
