| disable shutdown. derate - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: disable shutdown. derate (/showthread.php?tid=5789) Pages: 1 2 |
RE: disable shutdown. derate - Lonestar10 - 02-09-2020 makes the emission system a bit more lenient, reduce some egr to save the engine, disable the shutdowns that will put you at 5mph and on a hook. some of the things ive heard of for compliant tunes. big thing is though if your engine starts throwing codes that would normally cause a shutdown you need to get to a safe place ASAP and fix it as with the shutdowns off you can destroy your engine that much easier with plugged up exhaust. RE: disable shutdown. derate - dusty - 02-09-2020 ok, so where do you get the manual for doing that? RE: disable shutdown. derate - Lonestar10 - 02-09-2020 From the minds of the pros knowing which setting to tweak this way and that way. Rawze, Unilever's, momaburt, gearhead maybe a couple of other members. |
