| First time truck owner and first time poster - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: First time truck owner and first time poster (/showthread.php?tid=5795) Pages: 1 2 |
RE: First time truck owner and first time poster - JimT - 02-08-2020 (02-08-2020 )sprayerman Wrote: Ok bare with me I'm just trying to learn about this fuel pump. When you say change all the guts are you talking barrels, plungers and tappets? Even if they appear to have been done once already? Thanks Correct. Do them all together. You're gonna open it up to visually inspect it yourself, might as well future-proof it. Think of it as an insurance policy. You pay a little upfront to safeguard against a massive cost later. If any of those parts fail then the broken pieces work their way through the entire engine. You don't want to be driving down the road every mile wondering if one of the original parts of that pump head started dropping metal shavings into you oil, working it's way into all the places that it should never be. Just because the part looked good 150,000 miles ago doesn't mean it still looks good now, or a week from now. Change them out now and that's one less thing to worry about for another 400,000 miles or so. RE: First time truck owner and first time poster - hhow55 - 02-08-2020 (02-08-2020 )sprayerman Wrote:(02-08-2020 )Rawze Wrote:(02-08-2020 )sprayerman Wrote: .. Yes, indeed RE: First time truck owner and first time poster - Soulreaver0102 - 02-09-2020 Take it from me and everyone else that has mentioned the fuel pump. I bought a Freightliner with a 2250 in it. Full maintenance records and fuel pump had been opened checked and new plungers put in same as yours. Thought I was good to. Little did I actually know. Worked on truck couple days replacing sensors and getting truck ready to be put to work. First day first load 2 miles out got the dreaded 0559 code. Guess what? Yup. Fuel pump. Thanks to Rawze for beating a little sense into me I shut the truck down and got it to shop. That’s when I found out what happened. Luckily I didn’t destroy the engine but I took the route of fighting with company I bought the truck from and finally getting them to foot the entire bill but at a cost of truck being down for 3 months and idiots at dealership. $15,000 roughly over a fuel pump failure. Luckily I still had my other truck I was able to run while the Freightliner sat. Don’t postpone getting that pump dealt with. You could regret doing that. Best of luck bud. |
