What's the proper way to use the jake brake - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: What's the proper way to use the jake brake (/showthread.php?tid=6220) Pages: 1 2 |
RE: What's the proper way to use the jake brake - Nilao - 06-02-2020 As far as the high delay and mountain grades, you should already be in the gear you plan on going down the grade before you start down that grade. Miss that shift and you might not get it back in. I read somewhere that the engine fan has a max revolutions of 2400 before it would explode. I'd imagine a fan like mine with 10 years of use would probably fail at a lower RPM. |
