Gearbox Question - Printable Version
+--- Thread: Gearbox Question (/showthread.php?tid=682)
Pages: 1 2
RE: Gearbox Question - gearhead - 07-29-2016
I found the manuals also but no part number for this bleeder or relief valve.
RE: Gearbox Question - PuroCumminsPower - 07-29-2016
Thanks for all the feedback. I ended up loosening nut and found some debris under nut. Cleaned it up and the leak stopped.
RE: Gearbox Question - jimeneztrans84 - 07-29-2016
That's good easy fix!! Those gear boxes are a pain once they start leaking....
