Oil Temp Gauge Install? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Oil Temp Gauge Install? (/showthread.php?tid=7444) Pages: 1 2 |
RE: Oil Temp Gauge Install? - Rawze - 06-16-2021 (06-16-2021 )Drichardson1987 Wrote: I dont have the insite software to see what the engine is reading. I was just hoping to find a bung in the block that has an oil passage that I can access. I know there are quite a few on the oil cooler, but im not sure if any are before or after the cooler, and where the proper place to monitor would be.. fyi: aftermarket oil temp sensors are typically installed into the side of the oil pan. |
