| Correct height rear leveling valve - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Correct height rear leveling valve (/showthread.php?tid=990) Pages: 1 2 |
RE: Correct height rear leveling valve - Magard - 09-08-2019 (09-08-2019 )flatbed94kid Wrote: Maybe i'm thinking of something different but isn't their a linkage with holes and that is what you adjust it with on some models?Some are rubber eyelets with a rod and hose clamps on the rubber. Always good to be in spec for driveline sake. RE: Correct height rear leveling valve - DosGatos - 09-17-2019 Option 9. Park on a flat surface and adjust leveler for the 5th wheel height you want. Don't stretch the bags. Then go to a frame shop that does drivelines and have the angles measured from the transmission to the rear axle. Numbers go in software abracadabra update shims. [attachment=5451] RE: Correct height rear leveling valve - SquareOne - 09-17-2019 FBK, where the valve bolts on , one of the 2 holes are slotted in order to achieve the proper height.....just in case you missed it. |
