| QSC8.3 CM554 CAPS - How to get .xcal file - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: QSC8.3 CM554 CAPS - How to get .xcal file (/showthread.php?tid=9996) Pages: 1 2 |
RE: QSC8.3 CM554 CAPS - How to get .xcal file - Rawze - 03-09-2025 (03-09-2025 )collinthomson1 Wrote: Oh I’m so how would you suggest getting back the 300 hp file Cummins was only able to flash a 265 hp ecm is reman from them maybe month old The stealers$it likely did what they typically do. They probably re-flashed it with the program that belongs to that ser# engine?. ESN# 60326276 - CPL-8153: Calls for program J92002(240HP). RE: QSC8.3 CM554 CAPS - How to get .xcal file - J99 - 03-10-2025 (03-09-2025 )Rawze Wrote: on pre-2007 stuffs, [size=medium][b]YOU CANNOT FLASH BACK IN, A FILE THAT YOU COPIED OUT OF THE ECM!!!! --- THE COPY-OUT PROCESS CORRUPTS THE FILE!!!!. YOU CAN READ IT, VIEW IT, AND EVEN EDIT IT... BUT YOU CANNOT FLASH IT BACK IN!!!. ... Thanks for the advices. So I can confirm that trying to reflash back the file out of the ECM with CalTerm 5.16, it failed and left the ECM in rom boot state. Good news is that using Calterm 3.17 and the official Cummins Incal file, I was able to reflash it well, no issues. I feel electronics look to work normal now : Correct Temporization on the Lift Pump, Fuel getting out of the Injectors Control Valve at a regular pace when cranking. All the ECM Advanced Features working from Insite OK, etc. Only one Active error 268 from last time it started did not get away, but I am hopeful it will once it starts. It won't start yet but situation improved after bleeding air from 3 injectors nozzles (more white smoke when cranking, nearly starting). I will try to continue bleeding air from the return tube banjo soon, as clearly the bleeding is not "automatic" thanks to the lift pump as per the book. |
