ABS Trailer Brake Idiot Light... 2008 ProStar - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: ABS Trailer Brake Idiot Light... 2008 ProStar (/showthread.php?tid=1031) |
RE: ABS Trailer Brake Idiot Light... 2008 ProStar - linadin - 01-30-2017 ok so i have cured the problem. If you are having the same issue you have two choices. first one is to replace all the wiring from the plug located under the truck near the fire wall back. or you can go to a electrical supply store and pick up a can of electrical contact/circuit breaker cleaner and spray the contacts this will clear your problem right up. |
