| Bypass Oil Filter - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Bypass Oil Filter (/showthread.php?tid=1640) |
RE: Bypass Oil Filter - Rawze - 04-12-2017 (04-12-2017 )t700 Wrote: I do not want to extend oil change intervals. My presumption is that they do not really lower micro wear metal content in an analysis, but you never know. RE: Bypass Oil Filter - 05ISX450 - 04-13-2017 (04-12-2017 )Rawze Wrote:(04-11-2017 )05ISX450 Wrote: I never said I do extended oil drains. I do not ! I will say that there is a lot more filter material than with the Amsoil set up. Filters are less expensive too, 1 because it doesn't say Amsoil on it and 2 because you just buy the filter, with no metal spin on housing. Just my 2 cents worth. It's all good Rawze! Going on a long awaited vacation! Will post pictures, and info when I get back. RE: Bypass Oil Filter - Toolguy - 04-21-2023 (04-01-2017 )Brock Wrote: http://www.amsoil.com/shop/by-product/filters-and-by-pass-systems/by-pass/filters-and-mounts/heavy-duty-bypass-system/?code=BMK30-EA BMK22-EA is the Dual Guard system. It takes 2 filters, EABP90, EABP100, EABP110. 2 - 90's for oil capacity's 15 Qts. to 36 Qts. 2 -100's for oil capacity's 15 Qts. to 48 Qts. 2 - 110's for oil capacity's 15 Qts. to 60 Qts. The Dual Guard has been around for a long time. The BMK30 is the way to go with the EABP 120 filter. You will spend up to $90.00 for 2 filters, The Dual Guard is something like $300.00 to $400.00 plus filters. The 120 is around $45.00 to $60.00 plus. Amsoil just changed the $ amount. RE: Bypass Oil Filter - GunRunner - 09-12-2023 Does anyone have a suggestion on a bypass system that is comparable to the Amsoil single filter setup? I emailed Amsoil since the BMK30 and EABP 120 filters are out of stock and they said they don't expect them back in stock for several months. I looked at the BMK22 with two EABP 110 filters and don't mind running that if that's the best and most cost effective setup available. Just didn't if there was anything better that was more cost effective. RE: Bypass Oil Filter - Toolguy - 09-13-2023 (09-12-2023 )GunRunner Wrote: Does anyone have a suggestion on a bypass system that is comparable to the Amsoil single filter setup? I emailed Amsoil since the BMK30 and EABP 120 filters are out of stock and they said they don't expect them back in stock for several months. I looked at the BMK22 with two EABP 110 filters and don't mind running that if that's the best and most cost effective setup available. Just didn't if there was anything better that was more cost effective. Go back onto the Amsoil WEB site and look up dealers in your area and contact them to see if they have one in stock. Two larger dealers are Amsoil Synthetic Warehouse, he has a large store and carries a lot of product. 1-800-576-0580, web site is, Oilordering.com he also has a lot of youtube video's, Amsoil Synthetic Warehouse. Another large dealer is Best-Synthetic-Oils.com. You can ask the above dealers about the Dual Guard system, the only thing is you have to by 2 filters. Eather 100's or 110's. Thit was the original system for large engines. My friend put the dual guard on his 2000, 900 with a Detroit 12.7, 60 Series just becouse it has dual oil filters. Then he put on a dual coolant filter from fleetguard and made a custon P/S tank with dual filters on the outside. This truck was a working show truck. Good Luck. RE: Bypass Oil Filter - GunRunner - 09-13-2023 I didn't think about contacting a few dealers, thank you for the idea. I guess if all else fails, I'll put the dual system on. I guess it can't hurt to have two filters other than having to buy two. I'd rather get something on now than wait for Amsoil to get some back in. Thanks again for the info. (09-13-2023 )Toolguy Wrote:(09-12-2023 )GunRunner Wrote: Does anyone have a suggestion on a bypass system that is comparable to the Amsoil single filter setup? I emailed Amsoil since the BMK30 and EABP 120 filters are out of stock and they said they don't expect them back in stock for several months. I looked at the BMK22 with two EABP 110 filters and don't mind running that if that's the best and most cost effective setup available. Just didn't if there was anything better that was more cost effective. RE: Bypass Oil Filter - Toolguy - 09-14-2023 I found an AMSOIL Dealer in California that has 3 BMK30 HD kits but no 120 filters. Maybe you can locate filters somewhere else he said in his email could look around. Here is his information: Alan Cameron AMSOIL Depoit 100 El Camino Real San Carlos, CA 940770 1-650-654-2040 Sorry forget the email San Carlos is in the Bay area west side, between San Jose and San Francisco. He didn't give me any prices. Good Luck RE: Bypass Oil Filter - GunRunner - 09-15-2023 I got ahold of the Best Synthetics guy and he sold me the BMK30 that he used for a show sample/display. Has the filter and all and he sold it to me at 50% off. Thanks again for the idea (09-14-2023 )Toolguy Wrote: I found an AMSOIL Dealer in California that has 3 BMK30 HD kits but no 120 filters. Maybe you can locate filters somewhere else he said in his email could look around. |
