| Compression test - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Compression test (/showthread.php?tid=2606) |
RE: Compression test - JMBT - 01-17-2018 I’m with Rawze, I think the cylinder cut out test, one at a time will tell you all you need to know about the integrity of each cylinder. Cracked piston, glazed liner, or broken rings, any and all will show themselves. Then you can spend all the time you would have spent tearing down to compression test, on inframing if you need to. Just my $.02 |
