| 2350 fuel rail decay - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: 2350 fuel rail decay (/showthread.php?tid=5906) |
RE: 2350 fuel rail decay - Lonestar10 - 03-05-2020 well idk what resealed means unless its new orings or something but i would guess either the feed tube wasnt installed right or those injectors are internaly fubar. RE: 2350 fuel rail decay - Jokerone33 - 03-12-2020 Update I changed out #2 and #6 injector tan decay test and it dropped about 3-500 psi in 3 min so that is fixed but I still need to figure out how to get the program pulled out so I can get it sent over to Rawze to be gone over so I know what I’ve got good bad or indifferent but I’m not super savy with the computer lol RE: 2350 fuel rail decay - snailexpress - 03-13-2020 (03-12-2020 )Jokerone33 Wrote: UpdateJust friendly reminder, did you change injectors codes in Insite? RE: 2350 fuel rail decay - Jokerone33 - 03-13-2020 (03-13-2020 )snailexpress Wrote:(03-12-2020 )Jokerone33 Wrote: UpdateJust friendly reminder, did you change injectors codes in Insite? Yes I did thanks RE: 2350 fuel rail decay - SquareOne - 03-13-2020 (03-13-2020 )snailexpress Wrote: Just friendly reminder, did you change injectors codes in Insite? ^^ Such a legit question....when I first purchased my truck, not one injector code was correct after the engine was replaced. ----> The same 'mechanic' (lmao) also told me that 2250/2350 injectors were the same and could be interchanged if one were to fail...hmmmmmm RE: 2350 fuel rail decay - Rawze - 03-14-2020 (03-13-2020 )SquareOne Wrote: ... not so at all. RE: 2350 fuel rail decay - SquareOne - 03-14-2020 (03-14-2020 )Rawze Wrote:(03-13-2020 )SquareOne Wrote: ... Yep ^^, you explained that to me in detail when I was over at the compound last year upon first purchasing my truck.... Just a shame how many uninformed 'professionals' exist out there. It's acceptable to be ignorant on a topic...ignorance can be repaired by educating oneself on the matter at hand. Now stupidity....thats a whole other discussion. 'You can't fix stupid' is displayed amongst many of those so called 'professionals' at other's expense... |
