Anyone get code 1911 for cm2250? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Anyone get code 1911 for cm2250? (/showthread.php?tid=654) |
RE: Anyone get code 1911 for cm2250? - jimeneztrans84 - 07-21-2016 That's exactly what I feel is if I let go of the throttle then punch it, but it does it when truck is at full temp too...it's getting annoying RE: Anyone get code 1911 for cm2250? - jimeneztrans84 - 07-22-2016 Ok so after doing some test the truck was at 20 psi fuel pressure and has air coming from both tanks and maybe an injector or fuel pump head. Will do some more testing monday. The base of the water separator filter was full of dirt and almost looked like mud!!! After cleaning that we'll the truck started better and sounded better. Will keep you guys posted on Monday to see what is the cause... also swapped out fuel pump actuator and that wasn't it either.. RE: Anyone get code 1911 for cm2250? - Rawze - 07-22-2016 It sounds to me like you have some kind of serious fuel contamination. did someone get mad at you and dump dirt into your fuel tank? RE: Anyone get code 1911 for cm2250? - jimeneztrans84 - 07-22-2016 LOL that's what I'm thinking.... RE: Anyone get code 1911 for cm2250? - Jc_isx - 02-17-2020 (07-22-2016 )jimeneztrans84 Wrote: LOL that's what I'm thinking.... Did you ever figure out the issue. I'm going thru the same problem. |
