Freightliner Columbia 12.7 inframe - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Freightliner related help (/forumdisplay.php?fid=75) +--- Thread: Freightliner Columbia 12.7 inframe (/showthread.php?tid=7493) |
RE: Freightliner Columbia 12.7 inframe - Eby6114 - 07-01-2021 So I removed the oil pan and did a pressure test with what seems to be good results. It started leaking at the very front wall of the crankcase. The only thing I can think of is the water pump leaking into the engine. I went ahead and ordered it. Will install it and do another pressure test. Thanks for all the suggestions. |
