| 05 CM870 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: 05 CM870 (/showthread.php?tid=9371) |
RE: 05 CM870 - 3406E - 02-03-2024 (02-03-2024 )Rawze Wrote: Are you sure the ecm or vehicle is not in a starter lock-out condition due to anti-theft?. - Just some thoughts if it is not a wiring issue. if its anti theft how do i know or disable it? Insite? RE: 05 CM870 - Rawze - 02-04-2024 (02-03-2024 )3406E Wrote:(02-03-2024 )Rawze Wrote: Are you sure the ecm or vehicle is not in a starter lock-out condition due to anti-theft?. - Just some thoughts if it is not a wiring issue. The red check engine light will be on in the dash... and there will be fault codes associated with it. |
