| X15 chuffing through air cleaners at low rpm on jake brake - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: X15 chuffing through air cleaners at low rpm on jake brake (/showthread.php?tid=9372) |
RE: X15 chuffing through air cleaners at low rpm on jake brake - Jakt2016 - 05-11-2024 They sent me a replacement. It didn't change it. I believe I have a couple of weak jakes. I just haven't had time to check them. I've been driving it a Lil different. I usually let the rpms drop out with the jakes to push it out of gear and down shift. Been doing that way for 25 yrs. So now I pull it out at about 1300 and downshift. It hasn't done it since. But I've got to pull the valve cover and check the jakes running. Thank you for your help. RE: X15 chuffing through air cleaners at low rpm on jake brake - Rawze - 05-11-2024 (05-11-2024 )Jakt2016 Wrote: They sent me a replacement. It didn't change it. I believe I have a couple of weak jakes. I just haven't had time to check them. I've been driving it a Lil different. I usually let the rpms drop out with the jakes to push it out of gear and down shift. Been doing that way for 25 yrs. So now I pull it out at about 1300 and downshift. It hasn't done it since. But I've got to pull the valve cover and check the jakes running. Thank you for your help. - Although your program has nothing harmful towards the engine in it (the de-mandate part of it was done properly), the base program itself that was used to create it is very old too at this point too. The base program is more than 6+ years out of date. There have been a lot of fixes and updates by the red engine maker since then for that model engine. The de-mandate itself could also use some updating at this point too. I.E.> - It would be a good idea at this point to go ahead and update the base program itself + also update the versions of de-mandate to go with it. This can be done by ... ... backing up all the truck settings in Insite via a work order+ ecm template. ... Flashing the ecm back to its latest factory programming that belongs to that ser# engine. ... Restoring the truck settings into the new flashed program (restore the backed up template). ... running the engine on the new program for for 10 minutes to stabilize everything. ... then copying out the new program out with CT and e-mailing it to me, so that I can re-apply and update the rest. ... and then simply flashing back in, the updated copy after all the changes are made. ======= Who knows ... updating to the latest base engine software might even cure part of your issues ... but one never knows until its done. RE: X15 chuffing through air cleaners at low rpm on jake brake - Jakt2016 - 05-11-2024 (05-11-2024 )Rawze Wrote: - Although your program has nothing harmful towards the engine in it (the de-mandate part of it was done properly), the base program itself that was used to create it is very old too at this point too. The base program is more than 6+ years out of date. There have been a lot of fixes and updates by the red engine maker since then for that model engine. The de-mandate itself could also use some updating at this point too. I would really appreciate that Rawze! I'm on the road right now. I would prefer to do it at home in case something happens. As soon as I get home I will get it done. Thanks again! RE: X15 chuffing through air cleaners at low rpm on jake brake - Jakt2016 - 06-30-2025 Ive been meaning to update this for a few months now. In case anyone else has the same problem. I replaced turbo again. That was not the problem. About 40000 miles before I replaced the turbo originally. I had done the overhead. But this only started not long after I replaced the turbo. So I assumed it was the turbo. I eventually pulled the valve cover. And as soon as I did, I noticed the #1 cylinder jake lock down nut was missing. I almost had a heart attack. But it was still in the top of the head... Elongated with a couple of knife marks on it. So it definitely hit the cam. I went over every lobe at least 12 times and never saw, even a scratch. It looked brand new. Also while I was in there I noticed #2 jake adjusting screw was flush with the locking nut while all the rest where sticking up about.. I'd say 3/16 or so. I checked the adjustment and it was probably 3.5 mm or so. So idk what happened there. I would have definitely noticed the different in heights when I was doing the overhead. Also I used a crowsfoot to torque the locking nuts. And I know the were locked down. As I did the overhead, then I went back over each one again checking torque. Then I went in for lunch came back out and checked torque a third time before installing valve cover.So I'm certain they were locked down. This time I went over it with a wrench. Making sure they all were tight. It's been doing great for probably 50000 miles now. I just got lucky. It could have been a bad situation. RE: X15 chuffing through air cleaners at low rpm on jake brake - Rawze - 07-01-2025 Maybe a bit less beer next time when your in there. At least you found the issue. Thanks for the update. RE: X15 chuffing through air cleaners at low rpm on jake brake - Jakt2016 - 07-01-2025 Thanks for all your help Rawze and everyone! |
