| Grinding/growling noise coming from rear end - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Grinding/growling noise coming from rear end (/showthread.php?tid=10292) |
RE: Grinding/growling noise coming from rear end - Redland1 - 11-23-2025 Just wanted to give an update because I had forgotten to give one. The problem ended up being the ride height like a few on here suggested. Found the IROS 40k specs online and grabbed a rod the same thickness as the one on the leveling valve at tractor supply, and cut it down till I got the right height. Thanks everyone RE: Grinding/growling noise coming from rear end - Benjamin9669 - 12-02-2025 (11-23-2025 )Redland1 Wrote: Just wanted to give an update because I had forgotten to give one. The problem ended up being the ride height like a few on here suggested. Found the IROS 40k specs online and grabbed a rod the same thickness as the one on the leveling valve at tractor supply, and cut it down till I got the right height. Thanks everyone I was just about to mention even if it was off a {tiny bit}, it would still sound like the rear end was going to fall out lol. Had it happen to me. |
