Cummins 605/2050 immediate RPM drop issue - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Cummins 605/2050 immediate RPM drop issue (/showthread.php?tid=7797) |
RE: Cummins 605/2050 immediate RPM drop issue - Rawze - 10-22-2021 (10-22-2021 )tree98 Wrote: Yea a full load of BS there. If that were the case they could just give you a new ECM. Maybe you'll get lucky and be invited somewhere that can figure it out. problem is that anyone who touches it besides the OEM will void all the drive train warranty. RE: Cummins 605/2050 immediate RPM drop issue - tree98 - 10-22-2021 Yea, might not have much choice. RE: Cummins 605/2050 immediate RPM drop issue - WICT800 - 10-22-2021 I’m tempted to call the dealer I spoke with yesterday and see what they changed to make it work, if I need to pay for a technicians time I am ok with that, just bizarre because I know several other trucks that are both newer and older 2450’s that do not have this issue RE: Cummins 605/2050 immediate RPM drop issue - Lonestar10 - 10-25-2021 Technically by law they have to prove what you did broke whatever is under warranty but who has the cash to spend years in court to prove they didn't the one downfall to Magnus warrant act. RE: Cummins 605/2050 immediate RPM drop issue - AMC500 - 12-29-2023 Has anyone found the solution to this problem? |
