Drive line noise mystery? Solved - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Drive line noise mystery? Solved (/showthread.php?tid=2723) |
RE: Drive line noise mystery? - Rawze - 05-03-2018 (05-02-2018 )alborz Wrote: I think the guy at the shop put the rear/ rear spring for the front and the one for the front to the rear take a few photos of them and post em? RE: Drive line noise mystery? - alborz - 05-04-2018 [attachment=3887][attachment=3888][attachment=3889][attachment=3887] (05-03-2018 )Rawze Wrote:(05-02-2018 )alborz Wrote: I think the guy at the shop put the rear/ rear spring for the front and the one for the front to the rear Thanks Rawze Picture number 1 is front axle Number 2 rear axle And 3 rear rear yoke RE: Drive line noise mystery? - Rockhwy - 05-05-2018 I think you are right the spring that is on your front axle should be on the rear axle. You can Google leaf spring for peterbilt low air leaf and diagrams of suspension will come up from various web sites. You can also Google peterbilt low air leaf rear cut off and salvage yards have them for sale with pictures I looked at some and they all looked like spring with the bigger arch goes on rear axle if you had all 4 springs replaced looks like yours are opposite. I had a peterbilt with low air but was old style yours is new style like 2006 and newer Kenworth also uses your style I have peterbilt flex air kenworth also uses this suspension RE: Drive line noise mystery? Solved - alborz - 05-14-2018 Yes I was right The guy at the shop had. Put rear rear spring leaves on the front and frornt for rear. The slight bow shaped rear rear spring would make the axle to rotate upward and making the yuke inline with enteraxle drive shaft. Since he put rear spring for the front there ewas a mis alignment to both drive shafts and since the drive shafts and yuke wee rotating at different speed so that f.. noise was traveling up to the front and heard in cab plus unusual vineration. If you read this thread entirey you’ll understand what I have been through. All because an hourly guy made a simple mistake and the manager refused to review their work. RE: Drive line noise mystery? Solved - Chamberpains - 05-15-2018 Did the shop that made the mistake correct the problem immediately and at their expense? We understand things happen. But it's how they are handled and corrected that makes a reputation. RE: Drive line noise mystery? Solved - alborz - 05-15-2018 No They didn’t, as I picked up the truck and heard the grinding noise I turned back toward the shop. The guy who seems to be supervisor or manager didn’t accept their mistakes.. |
