| vibration damper thoughts - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: vibration damper thoughts (/showthread.php?tid=6086) |
RE: vibration damper thoughts - Hop along cassidy - 03-06-2025 (02-20-2025 )SquareOne Wrote: Does it change the vibration when switching through the different stages at a given RPM? Also, what kind of mileage are we talking on this setup? Did they mention the detent condition on the Jake rockers or the lobe condition the Jake rides on? It is not deleted the detent and lobes. Are good per Cummins inspection. The vibration doesn't really change through the differen stages other than stage 3. Having more vibrations just because it's holding back more. Power as far as the boost gauge, yes, the boost changes with the different levels. The Turbo and everything has been checked. The v g t all the they've changed the harmonic balancer i have yet to go pick it up and take it out and see what it does. Hopefully that fix the problem. |
