Engine brakes high level not working - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Engine brakes high level not working (/showthread.php?tid=10018) |
Engine brakes high level not working - Yady - 03-13-2025 I recently bought a 2016 Kenworth T680 that was de-mandated and I'm wondering how I can check it to make sure that it's correct. The issue I'm having is that the third level (high) of the engine brakes isn't working. RE: Engine brakes high level not working - Bengy88 - 03-13-2025 Does it still have vgt? If not then there’s your issue. Always assume a demandate is bad unless you’ve had it verified by someone trustworthy. If it is vgt deleted then it’s bad even if it’s good…. Read that twice. |
