Cm871 cylinder sleeve size??? - Printable Version
+--- Thread: Cm871 cylinder sleeve size??? (/showthread.php?tid=10053)
Cm871 cylinder sleeve size??? - Mrt800 - 04-03-2025
Is there any way to find what size of 152mm or 150mm without tearing it apart?
RE: Cm871 cylinder sleeve size??? - tree98 - 04-03-2025
Nope unfortunately there is not.
RE: Cm871 cylinder sleeve size??? - Mrt800 - 04-03-2025
Thanks .
RE: Cm871 cylinder sleeve size??? - marek4792 - 04-03-2025
Got to measure them manually when you pull yours out, Oring color use to determine size, but Cummins has been playing around with that too, so measure and verify everything!!
