2012 Workstar 7600 Switch Pack Power - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: 2012 Workstar 7600 Switch Pack Power (/showthread.php?tid=10064) |
2012 Workstar 7600 Switch Pack Power - danwald - 04-08-2025 Hi Can anyone tell me where the Dash Switch Pack gets its 12v power from? RE: 2012 Workstar 7600 Switch Pack Power - DVT873 - 04-08-2025 There should be a fuse for it in the fuse panel behind the cover on the passenger side. Check your PM, I sent you a link to download the manual. For some reason, the International Body Builder site does not have the circuit diagram for your year. There is some other good info there. https://www.international.com/products/resources/tem-body-builder/body-resources |
