| Injectors isx15 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Injectors isx15 (/showthread.php?tid=10085) |
Injectors isx15 - Nhramember - 04-24-2025 Good afternoon is there a difference between a2897320 and 2897320 xpi injector ? I bought a 2897320 xpi on it. Just curious thanks for info. RE: Injectors isx15 - windowrattler - 04-24-2025 2887320 isn't a valid part number for an injector from what i can see. Quickserve lists it as some type of gasket. RE: Injectors isx15 - Nhramember - 04-24-2025 2897320 RE: Injectors isx15 - windowrattler - 04-25-2025 So are you asking the difference between 2897320 and 2897320? It's the same number? If it's a2897320 that seems to be an aftermarket AFA brand injector. RE: Injectors isx15 - JimT - 04-25-2025 also a little unclear as to your actual question. Are you referring to the injector part number vs the new kit part #'s? I know cummins stopped selling some injectors by themselves and instead only sells them as part of a kit that comes with the injector tube which is also required to be replaced with a new injector. If you are comparing to an aftermarket injector then just stop! Don't even think about going aftermarket on an injector. |
