| QSX15 hard start/extended crank times w/black smoke - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: QSX15 hard start/extended crank times w/black smoke (/showthread.php?tid=10091) |
QSX15 hard start/extended crank times w/black smoke - dodges15152023 - 04-27-2025 QSX15 CM2350 X105/ 610DT Versatile 1500 operating hours. Owner info, Used only during planting season, Tractor has seemed to under-perform all its life since new, DManned by unknown suspect when new by dealer, (long-story) 1)The latest issue showed itself 5 days ago during planting. Hard Start/Extended and variable crank times both hot and cold. 2)Then planting rained out, 3) owner service fuel filter and air filters=no change to cranking issue.4)So owner dropped off, I connected, inactive fault codes i.e.559,5576,6583,285,3326,5663,197,235,689,778,115,3737, 2 active i.e. 6263,6472 fan control codes, (tractor has no fan controls). 4)Connected to "remote access and control" and a this Forum known tuner had file checked and repaired in effort to start fresh and as preventive start. Tractor put into service with only active fan control faults showing. Tractor performs in field nicely and satisfactory during and after 300 acre check in. 5)Tuning updates did not effect hard start/extended and variable crank times/ w/black smoke 6)Maybe unrelated but seemed odd. Can someone shed light on Insite Exhaust Gas Temperature (calculated) What specific/inputs/sensors does CI utilize to arrive at value. Cold Start @40 degrees ambient temperature day. While cranking C.I. shows EGTC variable values of 550 to 750 degrees. 7)Does this seem correct? During full pull 60' air/seeder 70+ rows EGTC show 1250+ Will try to post crank video.Cummins X15 extended crankFaultsFaults2 note: The photo's are pre-file update. The video is post update. RE: QSX15 hard start/extended crank times w/black smoke - Rawze - 04-28-2025 first of all, assume the old programming is bad + harmful to the engine. More than 90+% pof all de-mandate programming is. If you still suspect programming as part of the issue, simply copy the file out and email a copy of what someone did in there. info: https://rawze.com/forums/showthread.php?tid=8425&pid=72945#pid72945 Who knows what kind of progressive damage to the engine and/or turbo may have setting in with the bad delete programming it likely had in it. ====================== next, 559 code IS A VERY SERIOUS FAULT!. If the fuel pump itself is going bad, then it destroys the entire engine with it. It is nothing to ignore. Someone needs to pull the fuel pump head off and inspect it for damage and/or pitting of the pump crankshaft, and do plunger tests while they are at it. ref: https://rawze.com/forums/showthread.php?tid=6778&pid=60008#pid60008 Those fuel pumps need to be rebuilt every 8,000 hours or 400,000 miles, whichever comes first ... even if they look nice inside, to prevent engine destruction without any warning. ====================== NEXT: Will it pass a proper injector leak-down test at 29,000 PSI? .. to the test exactly as this video shows and see what the leak rate is... ref: https://rawze.com/forums/showthread.php?tid=8728&pid=75483#pid75483 RE: QSX15 hard start/extended crank times w/black smoke - dodges15152023 - 05-16-2025 Update on tractor, we finally resumed troubleshooting this unit, the engine passed the injection pressure test, running them through process multiple times to assure accurate results, interestingly is how well it held pressures. Ultimately the engine lost all of it's valve lash on the exhaust, at minus lash it was holding the exhaust valves open, the intakes where at .005/.007 All valve settings albeit tight where identical, so whatever was wearing was equal. I reset all the valves and the Engine starts and runs excellent. The tune had already been updated prior to running overhead. So did the old tune degrade the seats and/or valves? Do we pull the head to be on safer side and inspect? 1700 hours on engine. RE: QSX15 hard start/extended crank times w/black smoke - Rawze - 05-16-2025 bad delete programming can cause eccelerated valve seat wear. Copy the program from ecm and e-mail it to me for a proper review of what someone did in there if I have not reviewed it yet. RE: QSX15 hard start/extended crank times w/black smoke - Running rough - 05-17-2025 running stock (designed for EGR gas) timing without the egr, and or overfueling will cause severe valve seat wear, you have unsafe programming and i would fix that and replace head with new not reman before the valves drop and grenade your engine, if it was my engine i would cut counterbores and shim a and raise liner heights to .014, of course this calls for complete overhaul and reprogramming, but its the only way to be reliable going forward, my 2 cents |
