T880 won't overinflate, any ideas where to start - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: T880 won't overinflate, any ideas where to start (/showthread.php?tid=10130) |
T880 won't overinflate, any ideas where to start - aktruckerdad - 05-18-2025 T880 won't overinflate, I have 2 levelers,one on rear frame and one on passenger side frame,I unhooked arm on rear leveler and it will fill/dump when I lift bar up and down...any suggestions what next? RE: T880 won't overinflate, any ideas where to start - Rawze - 05-18-2025 regulated pressure is not high enough?. you also need to ensure your not exceeding the bag pressure spec too. RE: T880 won't overinflate, any ideas where to start - aktruckerdad - 05-18-2025 It is high enough |
