Cm870 Rebuild kit - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm870 Rebuild kit (/showthread.php?tid=10134) |
Cm870 Rebuild kit - 3406E - 05-19-2025 Currently looking at rebuild kits from Cummins, it seems like they have a ton of different part number rebuild for the kits for my Engine serial 79060142. They have given me two different part numbers. One says 152mm liner kit other says 150mm. Why is this? Does it matter? RE: Cm870 Rebuild kit - 3406E - 05-19-2025 Just looked it up on quickserve, it’s showing Both 150mm and 152mm. Would like an explantion. Thanks RE: Cm870 Rebuild kit - Pigpen 2869 - 05-19-2025 2 Different liners. You dont know what u got until its apart. Unless u already overhauled it once RE: Cm870 Rebuild kit - marek4792 - 05-19-2025 Also you cannot rely solely on oring color anymore, measure all your liners incase you have an oddball one and order accordingly.. RE: Cm870 Rebuild kit - Rawze - 05-19-2025 (05-19-2025 )3406E Wrote: Currently looking at rebuild kits from Cummins, it seems like they have a ton of different part number rebuild for the kits for my Engine serial 79060142. They have given me two different part numbers. One says 152mm liner kit other says 150mm. Why is this? Does it matter? this info will help... https://rawze.com/forums/showthread.php?tid=9415&pid=79951#pid79951 and also this info towards building it back for a million miles vs half-arssing it... https://rawze.com/forums/showthread.php?tid=8105&pid=70606#pid70606 RE: Cm870 Rebuild kit - 3406E - Yesterday Does the wrist pin bushings for the road come in the rebuild kit or have to get seperately RE: Cm870 Rebuild kit - Rawze - Yesterday (Yesterday )3406E Wrote: Does the wrist pin bushings for the road come in the rebuild kit or have to get seperately does not come with kit unless its a platinum kit that has all new connecting rods. |
