| Hub oil lube question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Hub oil lube question (/showthread.php?tid=10164) |
Hub oil lube question - Toolguy - 06-16-2025 At what millage or time frame, weeks, month's or years do you change out your front steer axle and trailer hub oil? Thank you very much. RE: Hub oil lube question - hookliftpete - 06-16-2025 Usually do mine about every two years, not sure on otr guys, as I only run 50k mikes/year RE: Hub oil lube question - Rawze - 06-16-2025 (06-16-2025 )Toolguy Wrote: At what millage or time frame, weeks, month's or years do you change out your front steer axle and trailer hub oil? every 250k miles. Maybe you should read thru this official truck maintenance schedule and take some pointers on how to keep your truck healthy. Its for a Prostar, but most of it would apply to any truck... info: https://rawze.com/forums/showthread.php?tid=3092&pid=26680#pid26680 and like the bottom of that post states... Quote:If your one of those people who can't be bothered to perform and fill out a regular and proper maintenance schedule for your equipment whenever it is due .. THEN YOU ARE THE PROBLEM.. NOT YOUR EQUIPMENT!. RE: Hub oil lube question - marek4792 - 06-16-2025 Doing OTR, you should be checking your hub oil levels and condition every chance you get, visually and with a temp gun to spot potential bearing issues, especially with grease-packed hubs. Assuming you're removing the hubcaps it definitely won't hurt to check bearing end-play too and/or torque spec for the hubs equipped with the cone spacer, and reset the preload per manufacturer specs if the bearings aren't chewed up. Especially if you're seeing irregular tire wear. RE: Hub oil lube question - mikkhh - 06-17-2025 If you check or replace axle oil every 40k it is still possible to save axle by just replacing bearings compared to when there is full carnage. Quality oil should be used in axles. Cheap crap oil equals yearly axle overhauls/replacements. |
