Bendix slack adjuster - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Bendix slack adjuster (/showthread.php?tid=10172) |
Bendix slack adjuster - Porterave - 06-19-2025 When backing off a Bendix automatic slack adjuster, is it supposed to give resistance and make a clicking noise? Do I have to release the brakes when pushing back an automatic Bendix slack adjuster (push in the parking knobs)? RE: Bendix slack adjuster - SquareOne - 06-20-2025 Yes, resistance and clicking is normal, but manual adjustment should not be a regular occurrence outside of parts replacement on that particular wheel end. Get your air pressure at or above 90psi (be sure the truck is chocked properly) and release the park brake (push in the parking knobs, yes). - These few videos may help educate you a bit on the auto-slack adjusters... https://www.youtube.com/watch?v=QXA6GrJti8Q https://www.youtube.com/watch?v=vdtkJPPlQOU https://www.youtube.com/watch?v=60ZLWU-8e_U RE: Bendix slack adjuster - Porterave - 06-23-2025 The Bendix auto slack adjuster is not backing off. It tightened but now it will not back off. It seems to be seized. RE: Bendix slack adjuster - Porterave - 06-23-2025 Okay, that problem was solved. Right now I adjusted the slack adjusters and will see how that goes. |
