| Boost pressure - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Boost pressure (/showthread.php?tid=10180) |
Boost pressure - Ravenwood - 06-25-2025 Cm2350 600, reviewed file, demandated, put a new head and 6 injectors, then installed the revised file in. This thing performs better than ever, gained about 20 gallons of fuel in the tank a day. I noticed on the few longer grades my boost will peak around 39-40 psi. Every time it does I get the (intake manifold pressure voltage below normal code).Engine performance doesn’t seem to change at all just an annoying check engine/service advised. Checked the sensor on insite and it steady at 87.5 Any help would greatly be appreciated RE: Boost pressure - Rawze - 06-26-2025 (06-25-2025 )Ravenwood Wrote: Cm2350 600, reviewed file, demandated, put a new head and 6 injectors, then installed the revised file in. This thing performs better than ever, gained about 20 gallons of fuel in the tank a day. That is too high for a CM2350., It should crest at about 34~ish psi max. Get with whoever made the program and have them turn down the boost levels. RE: Boost pressure - Ravenwood - 06-26-2025 I’ll send you a pm RE: Boost pressure - Ravenwood - 07-08-2025 Would a bad exhaust back pressure sensor cause high boost and code the IMAP sensor? Demandated CM2350 with a good clean tune from you know who. RE: Boost pressure - Rawze - 07-09-2025 (07-08-2025 )Ravenwood Wrote: Would a bad exhaust back pressure sensor cause high boost and code the IMAP sensor? it can... the circuit being clogged can do it too. what fault code(s) are you getting?. RE: Boost pressure - mikkhh - 07-09-2025 Older IMAP sensors can read wrong. When if ever were IMAP and back pressure sensor replaced with GENUINE parts from reputable source? RE: Boost pressure - Ravenwood - 07-09-2025 (07-09-2025 )Rawze Wrote:Still getting voltage below normal whenever boost gets too high(07-08-2025 )Ravenwood Wrote: Would a bad exhaust back pressure sensor cause high boost and code the IMAP sensor? RE: Boost pressure - Rawze - 07-09-2025 (07-09-2025 )Ravenwood Wrote: ... what is the actual fault code number(s)?. There might be an update related to it. RE: Boost pressure - Ravenwood - 07-15-2025 (07-09-2025 )Rawze Wrote:(07-09-2025 )Ravenwood Wrote: ... I’ll see if it comes up tomorrow. I changed the exhaust back pressure sensor because it was cracked. There’s a lot of carbon in the hole that it screws into. With the amount of coolant that was coming out of the exhaust last season I can’t say I’d be surprised if all those lines are plugged with soot. |
