Coolant pressure - Printable Version
+--- Thread: Coolant pressure (/showthread.php?tid=10195)
Coolant pressure - Porterave - 07-02-2025
Is there a coolant pressure sensor on 2016 Freightliner Cascadia DD15?
There is this fan symbol on the dash that reads between 8-20psi. It is 0 psi now because truck is turned off. Is this the coolant pressure?
The truck had this coolant leak on the hose going to the radiator. The clamp was a little loose so we tightened that and are monitoring it.
RE: Coolant pressure - marek4792 - 07-02-2025
That would be your turbo boost pressure.
