| Odd issue…ecm overheating? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Odd issue…ecm overheating? (/showthread.php?tid=10222) |
Odd issue…ecm overheating? - dhirocz - 07-17-2025 2010 KW, 1.17m miles, ecm @ 5661 hrs. @m*m^2 years ago by the man. Ever since it has gotten hotter outside, I’ve had an issue with the engine randomly dropping boost and giving me a stop engine light and returning to idle while driving. It idles with no accelerator pedal response for a one to 30 seconds, then recovers. I’ve checked serial data line integrity, checked for 60 ohms from the terminating resistors, power and ground…possible shorts, etc. I even used my backup Cummins actuator when I replaced the turbo for having a stiff VG arm. What I discovered today is that while my truck normally runs at 170 unloaded, it will run close to 190 loaded with the A/C on because of the outside temp… which is when the malfunctions occur. If I turn on the fan, it cools back to 170 and the issues go away. Normally it runs at 170 with the fan on at idle, comes on around 205. Cooling system is full, radiator, water pump and related components all done with OEM when inframed at 927k. Should I maybe pull the ecm and use heat sink paste behind it to the cooler plate? Or should I plan on replacing the ecm because it is thermally sensitive? RE: Odd issue…ecm overheating? - Rawze - 07-18-2025 The ecm itself should not be that sensitive. What are all the active and inactive faults in the ecm?. RE: Odd issue…ecm overheating? - Btech - 07-18-2025 What you described sounds like it is loosing signal from the throttle position sensor. The codes stored in the ECM will give more insite. RE: Odd issue…ecm overheating? - dhirocz - 07-21-2025 I spent some time digging around, and behind the cylinder head I found a section of harness that the A/C had been dripping on, that was rotted out… it made a loud crack as it bent from the wire jackets breaking. Ugh. I replaced both the engine and forward chassis harnesses yesterday. So far it’s running pretty good today. I erased the codes that were inactive. They were: VGT turbo out of adjustment Coolant level low Throttle position sensor out of range I’m going to drive it locally for the day and see what comes back. |
