| Calterm configuration files - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Calterm configuration files (/showthread.php?tid=10247) |
Calterm configuration files - JSSDiesel - 08-06-2025 Working with a CM871, trying to upload ECM file with Calterm (just got Calterm and I'm trying to learn how to use it). I read through Rawze's posts on using Calterm but I'm confused about selecting the configuration file. When I go to browse there is a "BAC" folder for the 871 but its empty. Do I need to download the configuration files from somewhere before I can even connect to this ECM to upload it? RE: Calterm configuration files - APC - 08-06-2025 depending on where you got your version of c a l t e r m from, they usually come with E C F G files... if not, you'll have to search the internet for the specific one you need for your calibration version. |
