8.3 ISC Tuning - Printable Version
+--- Thread: 8.3 ISC Tuning (/showthread.php?tid=10252)
8.3 ISC Tuning - nosgsxr - 08-08-2025
New to the form and have been looking around but not sure where to start. I have seen several names on here but not sure if anyone is better with the Cummins than others. Can anyone point me in the correct direction for help with a tune for my 2011 8.3 ISC ( it still has the DPF junk on it) in a motorhome?
RE: 8.3 ISC Tuning - Rawze - 08-08-2025
(08-08-2025 )nosgsxr Wrote:  New to the form and have been looking around but not sure where to start. I have seen several names on here but not sure if anyone is better with the Cummins than others. Can anyone point me in the correct direction for help with a tune for my 2011 8.3 ISC ( it still has the DPF junk on it) in a motorhome?
maybe this helps...
info: https://rawze.com/forums/showthread.php?tid=8425&pid=72945#pid72945
RE: 8.3 ISC Tuning - nosgsxr - Yesterday
maybe this helps...
thanks for the reply. with the inline-6 data-link adapter kit will i be able to pull the info needed to email this to you if i do end up getting an update the the ecm? i think i have an EGR problem and trying to figure out where to go next.
RE: 8.3 ISC Tuning - Rawze - Yesterday
(Yesterday )nosgsxr Wrote:  ...
Many things can be done to the engine file once its copied out.
