2022 2350 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: 2022 2350 (/showthread.php?tid=10253) |
2022 2350 - scott441974 - 08-08-2025 Anyone ever have a lower idler gear seize up and lock the engine up? I've had 1 do it about a year ago. Motor only had around 350k on it. Now I believe I've had a 2nd do it. Engine has 350k on it. Oil looks like it was cooked in the bolt holes of shaft on the oiling spindle. RE: 2022 2350 - Rawze - 08-08-2025 Pull the high pressure fuel pump head off and inspect its guts. If it looks like hamburger meat.. then you got much bigger problems than an idler gear. |
