| Proride XT - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Proride XT (/showthread.php?tid=10254) |
Proride XT - Ricky - 08-09-2025 I see that Rawze posted the numbers for the bags and shocks. Are those the numbers for the four bag system or the two bag? RE: Proride XT - Yauchout - 08-09-2025 the 4 bag shock is 83009hd gabriel and TRP airbag sc29b but I'm pretty sure they are the same part numbers for the two bag RE: Proride XT - Ricky - 08-09-2025 (08-09-2025 )Yauchout Wrote: the 4 bag shock is 83009hd gabriel and TRP airbag sc29b but I'm pretty sure they are the same part numbers for the two bagYeah, I have that bag number off my bag but I have gotten three different numbers from different places that it crossed to and all have to be ordered. RE: Proride XT - Ricky - 08-09-2025 (08-09-2025 )Yauchout Wrote: the 4 bag shock is 83009hd gabriel and TRP airbag sc29b but I'm pretty sure they are the same part numbers for the two bag Peterbilt crossed it to AS70920 Freightliner crossed it to W023587092 which is a big bag. Peterbilt can't order it until Monday but will have it Tuesday at around 42 bucks a bag. Going to do all four at once, instead of doing one every time I turn around. I have to work Monday and Tuesday, I saw where someone put spray foam in one to get it by. I'm all about Jerry rigging but I have to work and it's not to bad. Just don't want that foam getting pushed into the leveling valve. RE: Proride XT - tree98 - 08-09-2025 (to get you home/off the side of the road) - Cap off the line going to that bag. Then fill the bag with foam?. RE: Proride XT - Ricky - 08-13-2025 I was delivering in Charlotte, NC so I got two bags from them because that's all they had. Part# AS70930 $55.44 and it's a TRP bag. Ordered the other two and the shocks from the Dunn, NC Peterbilt and they will be there Thursday. Put the two new ones on the passenger side yesterday, took about ten minutes. Used one of those little tiny bottle jacks that's about six inches tall. Took more time to get the stuff ready and then picked up then it did to change the bags. This has been a truly wonderful system, need to paint the brackets over the weekend. |
