| ISX15 Lift pump - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: ISX15 Lift pump (/showthread.php?tid=10262) |
ISX15 Lift pump - Samvelm83 - 08-13-2025 Can electric lift pump throw metal shavings in the fuel filter? Does it have metal-to-metal friction inside? RE: ISX15 Lift pump - marek4792 - 08-13-2025 If you're well above 400k on the engine, I'd investigate the fuel pump for damage if you haven't done so already! RE: ISX15 Lift pump - tree98 - 08-13-2025 I think he's talking about the electric priming pump not the high pressure pump. Yes it can go bad and put metal in the fuel filter. RE: ISX15 Lift pump - marek4792 - 08-13-2025 Good to know Tree! RE: ISX15 Lift pump - Rawze - 08-14-2025 Like tree said though too.. Inspect that high pressure fuel pump while your at it. |
