| 870 turbo intake temp sensor wiring - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: 870 turbo intake temp sensor wiring (/showthread.php?tid=10279) |
870 turbo intake temp sensor wiring - tree98 - 08-24-2025 I have an 870 here that hasn't run in a few years. I took some of it apart and did a little paint work, then it sat for a while and now im back on it putting it all back together. Can anyone tell me if there is a short harness that connects these or where does the sensor plug into the harness on these 870's? [attachment=9979] RE: 870 turbo intake temp sensor wiring - marek4792 - 08-25-2025 Should a straight through connection, that one on top looks like for something on vacation. RE: 870 turbo intake temp sensor wiring - Milemizer - 12-11-2025 There is, may be a day late and a dollar short on responding for ya! Cummins part #3683086 was the one required for my 04 CM870 530hp. It should go into that connector shown on your engine harness. Hope this helps ya out. |
