| CM 2350 Egr slip joint - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM 2350 Egr slip joint (/showthread.php?tid=10301) |
CM 2350 Egr slip joint - farmtrucknw - 09-04-2025 Had a leak develop on my slip joint that goes from exhaust manifold to the front of egr cooler. Can this be removed and replaced without removing the whole exhaust manifold? I was told to switch to the bellows type joint I would have to replace the front portion of the exhaust manifold. Thanks. RE: CM 2350 Egr slip joint - tree98 - 09-04-2025 I replaced the whole exhaust manifold with a used one that had the bellows piece. That type you have is a bad design. As far as taking sections out and putting new ones in...... I've tried it without much luck. You can get them apart with enough heat, the problem I had was the new section would end up being too loose and wouldn't seal properly. |
