| Ecm - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Ecm (/showthread.php?tid=10332) |
Ecm - Scoot5869 - 09-29-2025 I may be needing a new ecm for my truck and I was wondering since I already have the programmed file in my computer do I still need to have the dealer put the factory files in it or can I just pop it in my truck and hook up to insite and load my existing file and be on my way? Also if I had my programming fixed a few years ago would it still fine or has the tune been updated. Thanks RE: Ecm - Rawze - 09-29-2025 When buying an ECM, ALWAYS buy it OEM,.. never off the interwebs or used, and ALWAYS have the stealers$it pre-flash the ecm so that it can run your truck before leaving there with it. This is cheap insurance that you have a good ECM. The moment you walk out of that door from then, you will have to buy a whole new one and wait months for your moneys back if there is anything wrong with it and/or f it does not work for any reason. RE: Ecm - Scoot5869 - 09-30-2025 Ok thanks I will have them pre flash it with the factory file then. Would my truck have the latest version of mm if you fixed it four years ago now I think RE: Ecm - Rawze - 09-30-2025 (09-30-2025 )Scoot5869 Wrote: Ok thanks I will have them pre flash it with the factory file then. Would my truck have the latest version of mm if you fixed it four years ago now I think If you send me the updated factory flashed file with 10 minutes of engine run time on it, then I can do it up with the latest version. RE: Ecm - Scoot5869 - 09-30-2025 Sounds good thanks |
