Nexiq and insite - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Nexiq and insite (/showthread.php?tid=10357) |
Nexiq and insite - Brocko93 - 10-19-2025 Hi all Have insite on my pc and I’m using a nexiq usb link 3 When trying to connect to the vehicle you get message to update the firmware in the usb link, click ok and then it says Cummins was unable to install the update. I can’t seem to find anywhere that you can download and update the adapters firmware away from Cummins. Any ideas? Cheers RE: Nexiq and insite - tree98 - 10-19-2025 You have to get the firmware updates from the nexiq website not from cummins. RE: Nexiq and insite - APC - 10-19-2025 (10-19-2025 )Brocko93 Wrote: Hi all PM Me if you need any help, I'll try to help you figure it out... |
