Newly demandated - Printable Version
+--- Thread: Newly demandated (/showthread.php?tid=10399)
Newly demandated - Emberlegion - 11-17-2025
I have a mechanic doing the mechanical items necessary to demandate. He told me he can do his own tune, but after reading your forum I know not to trust him. What kind of info do you need to send me a good tune file? Is it as easy as just running your file or is there excessive fine tuning once installed? I don't need any extra power(ruin engine life), I just want it to run as efficiently and smoothly as possible without the dpf/scr/egr. Thx in advance for your help or input
RE: Newly demandated - APC - 11-17-2025
assuming that you live in a place where it is legal to do the things you mentioned... the tuning process is a one time thing, not much fine tuning needs to be done once a proper demandated file is installed in the ECM. the tools required to read/write the file to the ECM is a laptop with windows on it, and a datalink adapter such as a NEXIQ USB Link or a Cummins INLINE adapter.
RE: Newly demandated - Rawze - 11-17-2025
maybe this helps...
https://rawze.com/forums/showthread.php?tid=8425&pid=72945#pid72945
