2021 X15 CM2450 – Low Intake Manifold Pressure (SPN 102 FMI 17) Persistent After New - Printable Version
+--- Thread: 2021 X15 CM2450 – Low Intake Manifold Pressure (SPN 102 FMI 17) Persistent After New (/showthread.php?tid=10408)
2021 X15 CM2450 – Low Intake Manifold Pressure (SPN 102 FMI 17) Persistent After New - hashi08 - 11-25-2025
Hi,
Yesterday morning I woke up to a check engine warning on my 2021 T680 with the X15 CM2450 (400HP). The active code is SA 0 | SPN 102 | FMI 17 – Intake Manifold Pressure.
I have already replaced the IMAP sensor, the Delta-P sensor, and the engine air filter. However, the same SPN 102 FMI 17 code continues to return.
I’m looking for assistance in diagnosing and resolving this issue so I can get back on the road. Thank you.
RE: 2021 X15 CM2450 – Low Intake Manifold Pressure (SPN 102 FMI 17) Persistent After New - Rawze - 11-25-2025
Is that cummins fault code 1363?. its complaining about low boost. That can be from many things including CAC leaks, clogging up exhaust system, etc.etc.
Did you use OEM sensor(s) replacements?.
did you so the rest of the EGR tune-up process?. Every other sensor in the system, and the entire EGR system will be as bad as that dirty sensor...
info: https://rawze.com/forums/showthread.php?tid=8438&pid=73167#pid73167
