870 coolant drip - Printable Version
+--- Thread: 870 coolant drip (/showthread.php?tid=10433)
870 coolant drip - 3406E - 12-15-2025
Not sure where this coolant is dripping but I traced it to this plate blockage thing on the side of the block. Gasket leaking? What’s even the name and purpose of it? Gasket part #? Image attached below
RE: 870 coolant drip - Bengy88 - 12-15-2025
That coolant is coming from up higher than that. What you are seeing is where it’s pooling up on the plate and dripping off, it can literally be anything. Stick a pressure tester on it and pressurize it and it should show up
