2016 DD13 GHG17 Cascadia - DPF filter longevity - Printable Version
+--- Forum: Freightliner related help (/forumdisplay.php?fid=75)
+--- Thread: 2016 DD13 GHG17 Cascadia - DPF filter longevity (/showthread.php?tid=10455)
Pages: 1 2
2016 DD13 GHG17 Cascadia - DPF filter longevity - dd13cascadia - 01-08-2026
Hey guys! Been lurking here for the longest time, barely posted. Figured i would change that, so i would make a thread to share with others that might be curious about this matter in particular. I hear, read and see lot's of differnt info across the board when it comes to the longevity of the DPF filters and the onebox. Well.... i have invoices and maintenance records to back my statement's up, since the truck was purchased up to now.....
2016 cascadia, with the specs mentioned on the topic title and just got the DPF filters changed as a precautionary measure at 836k miles. They were still OEM. Got cleaned at the dealer at around 630k miles in October 2022, the first time around. The mechanic said that they had a few soot spots, but nothing crazy and they would last more if i wanted.
I never idle overnight. Shut if off after 5 minutes whenever possible. Always warm up in the morning until the oil reaches 60 degress celsius then i drive. I use full synthetic 10w30 valvoline premium blue. Doesn't burn oil... oh! and since 2022... i never got the DPF filters cleaned. According to my OTR performance tool, the pressure differential on the DPF and temps were all normal while driving, but i started having interment MIL light flare ups. So i got the wiring harness for the aftertreatment changed as well. First time it got changed was in 2019.
Saying my prayers and got my fingers crossed, to see how much the onebox will last but i am hopefull that she will never quit on me! :D
Whats your take on this?
RE: 2016 DD13 GHG17 Cascadia - DPF filter longevity - mikkhh - 01-08-2026
How much idling time morning warmup takes?
What are your dpf differential pressure readings on idle? How big difference there was with the old DPF? Are regens more infrequent now ?
Intermittent MIL was caused by what faults codes? Maybe you have those for reference?
RE: 2016 DD13 GHG17 Cascadia - DPF filter longevity - Rawze - 01-08-2026
don't forget to do EGR tune-up work to the engine and EGR system on it at least once a year too.
https://rawze.com/forums/showthread.php?tid=7&pid=9#pid9
RE: 2016 DD13 GHG17 Cascadia - DPF filter longevity - dd13cascadia - 01-09-2026
(01-08-2026 )mikkhh Wrote:  How much idling time morning warmup takes?
I was going to say I didn't know on idle, but One of the last code reports I took was actually at idle. The other one, a couple days earlier shows a snapshot as I was rolling on the highway. I haven't checked with the new filters. Did my first drive today. Fuel mileage felt slightly better, but not much and too soon to tell. Route and weight was the same.
The code I had the most Was for the nox outlet sensor. Showed on the screenshot. The vehicle speed turned out to be the sensor by the transmission. Fortunately. Attached go oil samples. Note that there's one where the sample is high on wear metals. That's when I switched to Mobil Delvac from Valvoline premium blue (both 10w30) but the Mobil not being full synthetic and it Was a big mistake. Switched back to Valvoline premium blue and did rolling bearings just to be safe.
In the morning I low idle until oil reaches 35 Celsius and after that high idle till it reaches 60 degrees Celsius. All that talk about idling to warm up, I call BS. Stats speak for themselves.
(01-08-2026 )Rawze Wrote:  don't forget to do EGR tune-up work to the engine and EGR system on it at least once a year too.
Hey Rawze,
Thank you for commenting and for showing that link! I actually read your whole guide which I found very interesting. Learned a bunch as 2yo owner op. But, wouldn't this apply to or more to, the cummins engines? Because I had the egr cooler, crossover pipe and intake/turbo inspected a couple of months ago and they all looked clean.
Wouldn't the sensors throw codes? Also.. I never idle my truck.... Not even 300 hours in 10 years.. .for 836k miles and 21900 engine hours...
RE: 2016 DD13 GHG17 Cascadia - DPF filter longevity - mikkhh - 01-09-2026
How long oil change intervals?
There are many people here using cheap quality brand mineral oil without any issues regaring mineral oil being dirty or any visible pressurized lubrication parts wear.
How engine looks after running one million miles with mineral engine oil with proper oil change intervals:
https://rawze.com/forums/showthread.php?tid=4627&page=3
There has been gear oil added to engine oil too:
https://rawze.com/forums/showthread.php?tid=1913
(01-09-2026 )mikkhh Wrote:  How long oil change intervals?
Every 40.000km. I could go more, according to freightliner, but I prefer to follow the severe duty cycle. I do OTR/regional. Midwest/east coast.
https://www.summitracing.com/parts/vlv-818289
This is the oil I use. Couldn't vouch for this oil enough! I am going to look at those videos, but I am presuming you guys will agree that mineral oil on these newer engines is a no go?
RE: 2016 DD13 GHG17 Cascadia - DPF filter longevity - mikkhh - 01-10-2026
40 000km is way way way too long oil change interval especially on mandated engine.
How the engine looks inside? Really nasty and sooty?
I buy my oil usally in 208l drums. I use cheap 10w40 semi sythetic oldschool truck oil with added gear lube in all my equipment - mandated or pre mandate diesel cars, mini excavator, telehandler, even toys like PWC that have 1.5l 260hp supercharged gasoline engine. I used to buy 15w40 mineral, but it is not stocked anymore at the place where I buy oil and drum of 10w40 costs 10 bucks more than 15w40 drum. Winters can get -25c in my area that is also why I chose 10w40 this time. That super fancy fully symthetic oil costs 2-4x more, I buy cheap 15w40 mienral or 10w40 semi synthetic and do 2-4x more oil changes.
I used to run 15w40 in early 2000s diesel german cars year round even at winter for like last 7 years without any issues, also even to this day 15w40 oil in on oldschool diesel loader 12valve 5.9 engine is working with that oil for more than 15 years, max 2000hr farm use time, in it's former life it had 30 000 hours, no rebuilds, worked in a mine, had pretty hard life. Most likely it had 15w40 in it since day one.
RE: 2016 DD13 GHG17 Cascadia - DPF filter longevity - dd13cascadia - 01-10-2026
(01-10-2026 )mikkhh Wrote:  40 000km is way way way too long oil change interval especially on mandated engine.
I believe you! But as much as I know that older equipment runs well with those oil and mixtures, from all I have read and seen freightliner strongly discourages mineral oil or additives in the oil, especially on the newer Detroit engines. https://dtnacontent-dtna.prd.freightliner.com/content/dam/public/dtna-servicelit/ddc/pdfs/Lube_Oil_Coolant/DDC-SVC-BRO-0001_2021.pdf check here for The official Detroit info. Full synthetic for lubricity, low ash count to extend the life of the dpf, and extended oil drains (if you want to. I don't.) but aren't you confusing km with miles? 40k km is severe duty and the oil samples are perfect. One time I even did TBN/TAN and it was all good.
Check the included attachments for proof.
