| Rough running and stalling when pressing throttle - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Rough running and stalling when pressing throttle (/showthread.php?tid=10458) |
Rough running and stalling when pressing throttle - cumminsbear71 - 01-10-2026 I have done everything that I can think of that Rawze taught me to do. No codes, engine runs rough, dies under load, stalls at times when pressing throttle. What I've done Checked/replaced exhaust pressure sensor and s tube New MAP sensor New cam and crank position sensors New fuel pump and actuator (it was time) Clean filters Leak down test pass Cylinder cut out test was fine New throttle pedal just for good measure Demandated so no delta p? Right? Fuel pressure passed test New barometric pressure sensor I'm at my wits end. I'm sure it's something stupid that I forgot about but just can't think of it. Help? I'm really stumped. RE: Rough running and stalling when pressing throttle - cumminsbear71 - 01-10-2026 Oh I forgot. Recent overhead set. RE: Rough running and stalling when pressing throttle - mikkhh - 01-10-2026 What engine? CM... Programming has been pulled and looked over ? That would be the first thing to look over since you mentioned deman... RE: Rough running and stalling when pressing throttle - cumminsbear71 - 01-10-2026 Rawze programed it. RE: Rough running and stalling when pressing throttle - mikkhh - 01-10-2026 Are the replaced sensors genuine parts? What is the back pressure sensor reading? Intake manifold pressure? Oil temperature? Coolant temperature? Intake air temperature? What engine and how many miles? RE: Rough running and stalling when pressing throttle - Rawze - 01-10-2026 The only program help that I have on record from your e-mail addr is from several years ago. Rough running and stumbling, cutting out can be a lot of things. (blind guessing)... == Maybe Air getting in the fuel?. == Maybe the cans were not gutted properly and it has a lot of back-pressure in the exhaust?. - Has anyone tried to run it around the block with exhaust piping disconnected before the first can?, or behind trubo?. == What is the engine ser#? Maybe some more details, like when it started acting up, etc?. == Has anyone taken it on a test drive and collected data on it with a proper screen file in CT?. - That is the next step, as CT will tell you whats causing it to act up, cut out, stall, etc.. road test screen files. https://rawze.com/forums/showthread.php?tid=3317&pid=28636#pid28636 |
